Maybe I can get some help with creating a log file. I’m running LinageOS on a PI. And this is version 2.2.7. I have logfile set to CSV and selected several values to log. Is there another step I need to do to turn on logging?
Click on the top to display the menu. There will be an additional menu gear at the bottom right. There you will see the start of logging.
In the same place, the log entry is disabled.
Additionally you can make a button for your dashboard with an action to toggle datalogging on/off.
Thanks.
I knew it was something simple I was forgetting.
