Oil lubrication warms up 10-15 degrees more than coolant. Therefore, the operating temperature of the engine oil in a warm engine is in the range from + 90 to + 105 degrees.
Engine oil temperature is specified in OBD2 as PID 5C. This PID is also included in default OBD2 settings in RealDash. Unfortunately many vehicles do not send this information on standard PID, and this may be the case with your vehicle.
Yes that is kind of true. I have Oil temperature meter in my car’s original Infotainment and the Oil warms up much slower than the water. So would be nice to show accurately on the RealDash during Oil warmup. For example when the water temperature first reaches 90 degree the Oil temperature is only around 40 degree. So it takes a while for the Oil to “catch up”, which would make the calculated value way off.
Thanks, do you have any idea what PID’s would be used for Oil temperature for VW-Group cars?
