Hello
sorry - it is old problem/not critical - export config file
but not save settings
1/ settings / unit & values - speed source all time restore to the GPS sensor
2/ settings / unit & values - Page 2 Input Mapping - all time restore “Vehicle Speed IS SET FROM VSS1”
Regards
Falcon
I do not understand. If input mapping has value “Vehicle Speed IS SET FROM VSS1”, the vehicle speed source on page 1 cannot be GPS as input mapping is the one that determines that setting.
sorry. i will be sure : i was clear 100%
step by step
i get new device with RealDash
i made connection in garage and also setting skip into and other…
also i clear all data othe page 2 / settings / unit & values - Page 2 Input Mapping
GPS speed change to ECU inputs speed
then i export config file in garage
i get second new device with RealDash
inport config file
and i can see 2/ settings / unit & values - Page 2 Input Mapping - “Vehicle Speed IS SET FROM VSS1”
other setting is save
i hope now is total clear
Ok, I will test that scenario.
