Hi, I originally added a name value for torque converter lockup which is a represented as a byte with value 0 = off and value 1 = on (I assumed only bit 0 is changing); this is working fine, but I tried to tidy the xml entry up to use targetId=143 Lockup Active (Transmission) this being an on/ off value instead, without success
Original (working): name=“FJ: Torque Converter Lockup” conversion=“B1”
I have tried the following:
targetId=“143” conversion=“B1” units=“bit” and
targetId=“143” conversion=“B1>>0” units=“bit” (assuming the bit needed is already in the right place)
