Obd2 and usb can , turbo boost , afr, egt pleasse
Hello, I created xml with can analyzer v8 and I use it very well but I couldn’t convert some data like turbo pressure, exhaust temperature and afr to xml because I don’t have this information in my can bus line, when I connect obd2 these work in realdash but exhaust temperature doesn’t appear, also when I connect my usb device and obd2 bluetooth device at the same time some values ​​go astray, I’m thinking of creating xml for obd2, it’s enough if I get afr, torque, engine horsepower
exhaust temperature and turbo pressure in obd2, I can already read the others with xml usb. Can you give an example for obd xml? or can I read these values ​​with usb xml* Thanks, my biggest problem is that every time multimedia is opened I have to constantly select ok from the popup of use realdash for usb, we expect this to be solved with the new update.
Here is the documentation for OBD2 XML file format:
RealDash-extras/OBD2/README.md at master · janimm/RealDash-extras
