I’ve recently tried to change my connection from OBD2 to CAN for improved performance. When I use my OBDLink MX+ as a CAN adapter (via bluetooth to RealDash running on iPad), it only seems to read the first 12 frames. I have a 2013 Corvette LS Engine (E38 ECM). I’ve used the CANBUS XML files for GM LS engines from Github and also run it with no XML and always have the same result. No matter what I do, it only logs
0x0110
0x0120
0x0170
0x0300
0x0308
0x0320
0x0348
0x0410
0x0510
0x0520
0x07df
Google tells me the connection is overloaded and recommended some INIT strings to only pass through specific values. I tried that and still only get these 12. Any thoughts?
Thanks,
-Tom
