OBR Euro-8 ECU support
ECU is becoming very popular here in the states for doing engine swaps. Would be nice to have a great dash to go with it. The dashes that are available are race oriented and not suited for daily driver street use. The Euro-8 is the more common used ECU. I have attached a link to the pdf of the can bus information.
https://obrcontrolsystems.com/ecus/pre-programmed-engine-types-for-motorsports-systems/see-which-engine-configurations-are-pre-programmed-and-easily-selectable-in-our-efi-systems/
https://obrcontrolsystems.com/media/lyfff0fo/can2-data-export.pdf
Thank you
Bill
Thanks for sharing, I will add OBR Euro-8 CAN2 XML to next release of RealDash.
Thank you
This is now in 2.2.4. Completely untested though as we do not have test device. If anybody has a OBR Euro-8, help on testing is appreciated.
Thank you for adding this. I will forward the info to OBR and see if they can test it. They will be glad to add RealDash to the list of supported displays.
I have emailed OBR asking if someone there could test the application. I would test it but I am still waiting on my dash hardware.
Be looking for an email from Ole at OBR he is very interested in RealDash and will test it in house for you.
Thanks!
Hello, Should Euro-4 work on same can file ?
I do not know, but if you have access to Euro-4 CAN descriptions, its simple enough to compare them to Euro-8.
By the looks of it, no its not the same… if i understand it right..
I have links to the can datastream file and .dbc file, but this forum dont let me post the link here.
Posting links should work just fine? You can also send directly to me: contact@realdash.net
Lets continue via Email…
