I’m new in this topic and currently working on a Dashboard for my BMW Motorcycle.
I’m using a OBDlink MX+ device to connect the bike and a 8" Android Tablet.
I want to connect ODB2 Signals for showing motordata and also CAN Data for additional signals like gears, turn signals…
How do I need to connect the adapter to RealDash?
Do I need to connect “Adapters (CAN/LIN)” or “ODB2” from the Source list?
To use both at the same time you will need two adapters and connect to both connection types. The OBD2 option uses ELM327 compatible protocol to communicate with your bike, Adapters (CAN/LIN) connection type reads a stream of CAN data and requires you to write a XML file that describes the incoming CAN frames of how they are interpreted and set to RealDash inputs. For documentation of CAN XML, see: https://github.com/janimm/RealDash-extras/tree/master/RealDash-CAN
Thanks a lot for your support.
I understood most of the values in the .XML, but I have a question:
My bike shows the turn signal by B8 of ID 0x10c:
CF=Off, D7=Left On, E7=Right On, EF=Both On
How can I realize this in .XML and the in RealDash?
