Hey.
I sent my odometer through the terget iD 300 and converted it using .XML - this way I get my odometer reliably. I am checking with diagnostic equipment.
But I have little problems with the trippmeter that shows V * 10, so I drove 1.9 km, and the RealDash trippmeter shows 19 km of track.
although I did not add math to the sensor.
also the value “Range” for some reason shows miles instead of kilometers? Therefore, you have to multiply the value of V * 1.6 - after which the value is true!
What affects the “Range”?
The value from hex is always an integer. So you have 19, not 1.9. You need to always divide trip by 10
