I am not sure whether it is something I do wrong or a deficiency of the app, but it seems to me that tiles downloaded from OSM are not being cached. If I zoom in and wait until the tiles are downloaded and rendered and then zoom out to the previous level, it redownloads all the tiles again.
This is almost unusable on a slow internet links in rural areas. The likelihood of an area changing within, say, 6 hours is really low, so it would be great to cache tiles for 6 or 12 hours (or maybe even more).
Am I missing something and it works for everybody else and you can quickly zoom-in/zoom-out and browse the map?
Is there any way I can provide debug info or assistance in debugging this? My device is Samsung XCover 6 Pro (a standard Android phone from Samsung, well, it is the only rugged version they produce, but other than this it is a normal Samsung device like the rest of their line up). Just to ensure we are on the same page, I was referring to the default map widget in the default dashboard you get when you install RealDash from Google Play store. When I zoom in / zoom out in that circle widget, it looks like there is no caching at all.
Will test it out tomorrow when I pick my bike from the service and will let you know. Thanks for the amazing app. I started with DMD2, but was so disappointed and then I found RealDash. This is hardcore and is exactly what I was looking for. Thanks again!
OK, I tested with “Sweedish Special”, it definitely caches tiles. Moreover, after zooming in and out on that dashboard, when I switched to default one, everything was working as expected (I could not reproduce the issue anymore).
However, I noticed that even though the tiles are cached, when you zoom in and zoom out, you can still briefly see a light blue rectangle where the tile will eventually be loaded. Perhaps, drawing this part can be improved: like delay the redraw of the screen until cache is checked? This way it would be much smoother experience, IMO.
