Hello! I noticed that when using a video gauge in the Windows version, I can play a url from a TS file, but when opening it in the Android version, the url is not played in the gauge.
Is there any way to make it play on Android?
RealDash Android version uses Google’s ExoPlayer. It could be that ExoPlayer does not support the stream type that is in your TS file.
I can test the stream on Android if you’d share the URL for the stream. If you do not want to share publicly, send an email to contact@realdash.net
