When transferring a skin file to another device, the PLAYBACK settings for the video sensor and whether for the gif file will look correct in terms of Checkboxes, but they won’t actually match the checkboxes. to put them in order, you have to switch these settings again.
I have no idea what you are talking about ![]()
Playback settings such as repeat, live last frame, play on load, play on touch. if you set them up for some video sensor, then save the file. rd, then open the file on any other device. The behavior of the video sensor will not match the selected properties. For example: if you leave the “repeat” option inactive, then this sensor will be repeated on another device, despite the fact that the option is not selected. To prevent the video from repeating, you need to install and then delete the repeat option.A similar situation occurs with other options in the playback section.
