Hello, can you tell me where I can find an xml file for installation on a RealDash, car - Prado 150, 2014, diesel 3.0. Best regards - Victor!!!
@kseniy1962 Have you tried Toyota FJ Cruiser xml?
yes, but not all sensors on the Real Dash panel show, in particular - it does not show the fuel level. Maybe you can tell me where I can read information on creating an xml file. By the way, I looked at other topics, you posted an FJ file for Toyota, I’ll try tomorrow and write
Fuel level is not broadcast on the FJ Cruiser canbus, so unlikely you will find this on the Prado of similar age
Thanks for your attention, unfortunately your file does not support OBDII.
No this is a canbus xml file, I can send you an obdii file which I used initially before substituting values with canbus
toyota_fj_odb2.xml (4.4 KB)
Thanks, I’ll try it now
the file came up, but there is still no fuel level reading, I will have to tinker with this file myself. Once again, thank you very much for your attention…Victor…
There is one more question, is it possible to connect the Thinkdiag BD6 channel to RealDash?
