starting from version 2.0.2, maybe earlier. Editor mode in windows version. in earlier versions, if you freeze an element in the foreground, you could select the elements on the further layers with the mouse. currently, the selection under the frozen element is not possible. please fix. if i not clear i ready made video.
Thanks for reporting. Will investigate.
Edit: Found it. This bug was introduced while fixing the selecting gauges from nested containers. Fix coming soon.
