I connect the software data source via Realdash CAN, and the program immediately crashes. Version 1.7.6
The Board that connects the CAN bus and the computer sends 2 signals with a frequency of 50 MS to the CAN bus. Does it have any effect?
What data do you need to detect an error? the dump log was sent to you via the program.
It works without problems on Android
Ok, I will check the crash logs from Microsoft.
Did you find something about this problem?
Unfortunately not. I see from Microsoft logs that there are some crashes but there is no call stack or any other detailed info included.
We did fix OpenSSL related crashes for 1.7.7, is your crash problem still present on 1.7.7?
