Trying to configure realdash to talk to this over the bluetooth link -
no problems setting up the link - the XML file seems to be loaded ok -
but Real dash only repeats asking for the first 4 PIDS - refuses to look for the others ?
deleted the connection to the bluetooth and reconnected so as to pickup the default xml file -
still the same - not asking for any other pids -
so then I hard coded the OBD bridge to return FFFFFFFF to the 0100,0120,0140 etc -
realdash didnt seem to cope with this wery well at all - it asked for the 4 pids as previous - once and then appeared to stop -
after a few seconds it reinitilised the connection - repeat.
definately seems to have an issue with processing the supported pids commands.
ok - been trying to tackle it from other fronts - eg getting dash command to work with it etc -
fixed a couple of small bugs in the obd2 message handler at my end - tp do with initialisation responses - but nothing that had any effect on on this problem.
I did investigate this a little bit but could not find the problem. Could you share again just one PID that is sent and RealDash is not responding properly?
hmm - so in your case the realdash requested the codes in the rang 0120 and above ?
if so do you have a trace as i might be able to compare against the values returned for the 0100, 0120, 0140 etc request response pairs and check -
can you advise the simulator you are using ? i might be able to try something with it at this end ?
Easiest is if you could send me a log of the simulator and realdash comms - then I can try and figure it out at this end
Since OBD2 uses a poll mechanism, RealDash skips all requests that have no gauge associated. This is to optimize the speed of the data transfer since there is no point of requesting the value from the vehicle if there is no gauge to show it.
Try to make a dashboard that has gauges for all your ‘RAESAN’ specific values and the requests should go thru just fine.
Im sorry - I must be missing a step -
even though I have given the XML file with custom definitions -
Ive set the gauges to point to the custom defined values ( and the internal mapped variables)
it still seems to refuse to ask for the custom PIDS - it only really wants to ask for the RPM - .
Is there some other mapping between gauge and PID ?
it doesnt work either using the internal mapped value for the pid as defined in the XML - or direct.
is there an example about with custom PIDS that works that I can emaimne ?
currently Torque Pro =1 Realdash = 0
is there a way to reset it to a celan install and start again - just in case ?
