I’m attempting to use a hyperpixel display with a raspberry pi to run realdash. I’m able to get the display working with a desktop environment but when i launch realdash, the display will freeze and fade to white. I thought this might be an OS issue, so i tried with ubuntu. I had the same problem there. I believe this may be because realdash is using the same GPIO pins the display uses? Is there a way to disable the GPIO pins in realdash possibly?
Any advice is appreciated. Thank you
