Hi there, anyone can give me clear instructions and steps on how to set up a raspberry pi with the right OS and parameters for settings and how or what do I install to get RD working smoothly , a step by step guide link would be helpful. I’m torn between which OS I could use and what preparations I would need on the OS before I install RD.
If you are unfamiliar with Linux and how to install software into it, Android may be a better and easier solution for you. I think easiest way to get started is to buy a Automotive Android head unit.
As for installing Linux version, instructions are in this topic:
hey, is there any chance to install the neweste arm64 file ( realdash-mrd_2.5.9-2_arm64.deb) to my RPi 4B as a desktop programm? i want to use it with my carpihat shutdown gpio script. But i cant install it.
is there any chance, to get some help to install it as a desktop progamm?
here ist the issue text out of the terminal: pi@raspberrypi:~/Downloads $ sudo apt update sudo apt install -y libssl1.1 libgl1 libgles2-mesa libxkbcommon0 libopenal1 libvlc5 gpiod espeak-ng OK:1 Index of /debian trixie InRelease OK:2 Index of /debian trixie-updates InRelease OK:3 Index of /debian trixie InRelease OK:4 Index of /debian-security trixie-security InRelease Alle Pakete sind aktuell. Fehler: Paket libgles2-mesa kann nicht gefunden werden. pi@raspberrypi:~/Downloads $ realdash 18:37:20.058 os_linux.cpp(444)(tid:0x93408608) : NUTS_INFO - Speicherzugriffsfehler
