All of this worked fine on g4+ but as we know g4x has a CAN input timeout. I thought adding the writeInterval would solve it but i’ve tried 100-1000ms and I still get the timeout fault on the ecu end. Anytime I tap on either a DI or AN value up button on my RD, it refreshes the stream and my values show up in the ecu but after the 2 second timeout period it resets back to the no message fault.
I can only assume something in my XML is not allowing the writeInterval to work. FrameId 1004 is my buttons
S2000-Can-Streams-6.xml (4.3 KB)
