Hello everyone,
where can I display the version information in RD?
β
You need to use the one for whatever architecture you are running, what is your hardware?
Hello matt-c205,
many thanks for the answer.
Hardware is a Radxa Rock 5B
Software Linux Armbian 23.08
RD could simply write Win / Android / Linux etc. behind the downloads, then the assignment would be clearβ¦
β
BTW:
Where can I find the version information in my installed RD Linux version?
How do I update to the current RD version?
Can I also use the USB connection between Teensy and Rock5B instead of the Rock 5B GPIO to receive data from controllights and sensors in RD (no TTL or serial adapter, - real USB)?
Does this work with the XML file?
So you need one of the .deb with arm in the name, the hf one if your processor has a hardware floating point unit.
The different versions are more todo with CPU architecture than OS.
Version can be seen in Settings β Other β About
Install the new one over the top of the old one.
3 - you should be able to
