Reading Value 1 Time
I have an arduino I am sending analog sensors with plus one EGT probe. I edited the xml to target 106 instead of the RPM. All of my analog sensors are reading continually, but the EGT value only changes when the the arduino boots and no more after that. The simulated values on the arduino example are still changing.
I have an LCD I have been testing with and have the thermocouple.readfahrenheit displayed. The value is changing there as it should.
I am pretty new to all of this so I apologize if its something obvious. I’ve spent days trying to tweak things but with no luck.
Difficult to help without more info, like the Arduino sketch etc.
#include <LiquidCrystal_I2C.h>
#include <max6675.h>
 *  Name        : RealDash_CAN_2way.ino
 *  Part of     : RealDash
 *  Author      : Jani Immonen
 *  Created     : 15.10.2017
 * Arduino example sketch of how to use RealDash CAN protocol.
 * This example code is free for any use.
 * www.realdash.net
      LiquidCrystal_I2C lcd(0x27, 20, 4);
      //initialize the liquid crystal library
      //the first parameter is the I2C address
      //the second parameter is how many rows are on your screen
      //the third parameter is how many columns are on your screen
      unsigned int FUEL = A2;
      unsigned int DRIVE = A1;
      unsigned int BOOST = A0;
      //EGT
      int thermoDO = 31;
      int thermoCS = 33;
      int thermoCLK = 35;
      MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
      int egtRead = thermocouple.readFahrenheit();
      unsigned int egtLevel = egtRead;
// Arduino digital and analog pins
// digital pin statuses are stored as bits in one variable
unsigned int digitalPins = 0;
// analog pin values are stored in array of ints
int analogPins[7] = {0};
unsigned int rpm = 0;
unsigned int kpa = 992; // 99.2
unsigned int tps = 965; // 96.5
unsigned int clt = 80;  // 80 - 100
unsigned int textCounter = 0;
// incoming data
byte incomingFrame[17] = { 0 };
unsigned int incomingFramePos = 0;
// if READWRITE_PINS is defined, the values are read from and written to Arduino
// digital and analog pins.
#define READWRITE_PINS
void setup()
  #if defined (READWRITE_PINS)
  // set digital pins as outputs
  for (int i=1; i<14; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, HIGH);
  #endif
  // init serial
  Serial.begin(115200);
  delay(100);
      pinMode(53, OUTPUT);  //Set LED Warning Output
        digitalWrite(53, HIGH); //Test Warning Light
      lcd.init(); //Initiallize LCD
      lcd.backlight();
      lcd.setCursor(6,1);
      lcd.print("FUMMINS");
      delay(1000);
      lcd.clear();    //Reset
      digitalWrite(53, LOW);
void loop()
   //Boost Level
int boostSensor = analogRead(BOOST);                   //Read Boost Sensor
int boostLevel = map(boostSensor, 100, 1000, 0, 100);  //Map the Sensor
lcd.setCursor(0, 1);
if (boostLevel < 10) { lcd.print("0"); }
if (boostLevel < 1) { lcd.print("00"); }
lcd.print(boostLevel);
lcd.setCursor(2, 1);
if (boostLevel < 100) { lcd.print(" "); }
lcd.setCursor(3, 1);
lcd.print("PSI");
  lcd.print(" ");
lcd.setCursor(0, 0);
lcd.print("Boost");
//Drive Pressure
int driveSensor = analogRead(DRIVE);                   //Read DRIVE Sensor
int driveLevel = map(driveSensor, 110, 1000, 0, 100);  //Map the Sensor
lcd.setCursor(0, 3);
if (driveLevel < 10) { lcd.print("0"); }
if (driveLevel < 1) { lcd.print("00"); }
lcd.print(driveLevel);
lcd.setCursor(2, 3);
if (driveLevel < 100) { lcd.print(" "); }
lcd.setCursor(0, 2);
lcd.print("Ex Pres");
  lcd.print(" ");
lcd.setCursor(3, 3);
lcd.print("PSI");
//EGT
int egtLevel = thermocouple.readFahrenheit();
unsigned int egtmapped = map(egtLevel, 70, 1600, 0, 255 );
//analogWrite(13 , egtLevel);
lcd.setCursor(10, 1);
if(egtLevel < 10){
lcd.print("0");}
if(egtLevel < 0 ){ lcd.print("    ");}
if(egtLevel > 0) {lcd.print(egtLevel);}
if(egtLevel <100){ lcd.setCursor(12,1); lcd.print(" ");} //print blanks
if(egtLevel <1000){ lcd.setCursor(13,1); lcd.print(" ");} //print blanks
lcd.setCursor(14, 1);
if(egtLevel < 1000){lcd.print(" ");}
lcd.setCursor(10, 0);
lcd.print("EGT");
lcd.setCursor(15, 1);
lcd.print("F");
//Serial.print("F = ");
//Serial.println(thermocouple.readFahrenheit());
//Fuel Pressure
int fuelSensor = analogRead(FUEL);                   //Read Boost Sensor
int fuelLevel = map(fuelSensor, 110, 1023, 0, 100);  //Map the Sensor
lcd.setCursor(10, 2);
lcd.print("Fuel Pres");
lcd.setCursor(10, 3);
if (fuelLevel < 10) { lcd.print("0"); }
if (fuelLevel < 1) { lcd.print("00"); }
lcd.print(fuelLevel);
if (fuelLevel < 100) {
  lcd.setCursor(12, 3);
  lcd.print(" ");
lcd.setCursor(13, 3);
lcd.print("PSI");
if (boostLevel > 35 || egtLevel > 1200 || driveLevel > 50 || fuelLevel < 30) { digitalWrite(53, HIGH); }
if (boostLevel < 35 && egtLevel < 1200 && driveLevel < 50 && fuelLevel > 30) { digitalWrite(53, LOW); }
  ReadDigitalStatuses();
  ReadAnalogStatuses();
  SendCANFramesToSerial();
  ReadIncomingSerialData();
  // just some dummy values for simulated engine parameters
  if (rpm++ > 10000)
    rpm = 500;
  if (kpa++ > 2500)
    kpa = 10;
  if (tps++ > 1000)
    tps = 0;
  if (clt++ > 230)
    // all values in frame are handled as unsigned values. To use negative values,
    // offset actual value and write corresponding conversion to XML file imported to RealDash
    // From RealDash 1.7.6 its also possible to specify value as signed="true" in XML file.
    clt = 0;
  // simple counter for sending the text frame to avoid sending it too often.
  if (textCounter++ > 4000)
    textCounter = 0;
  delay(150);
void ReadDigitalStatuses()
  // read status of digital pins (1-13)
  digitalPins = 0;
  int bitposition = 0;
    if (digitalRead(i) == HIGH) digitalPins |= (1 << bitposition);
    bitposition++;
#endif
void ReadAnalogStatuses()
  // read analog pins (0-7)
  for (int i=0; i<7; i++)
    analogPins[i] = analogRead(i);
#endif
void SendCANFramesToSerial()
  byte frameData[8];
  // build 1st CAN frame, RPM, MAP, CLT, TPS (just example data)
  memcpy(frameData, &egtRead, 2);
  memcpy(frameData + 2, &kpa, 2);
  memcpy(frameData + 4, &clt, 2);
  memcpy(frameData + 6, &tps, 2);
  SendCANFrameToSerial(3200, frameData);
  // build 2nd CAN frame, Arduino digital pins and 2 analog values
  memcpy(frameData, &digitalPins, 2);
  memcpy(frameData + 2, &analogPins[0], 2);
  memcpy(frameData + 4, &analogPins[1], 2);
  memcpy(frameData + 6, &analogPins[2], 2);
  // write 2nd CAN frame to serial
  SendCANFrameToSerial(3201, frameData);
  // build 3rd CAN frame, rest of Arduino analog values
  memcpy(frameData, &analogPins[3], 2);
  memcpy(frameData + 2, &analogPins[4], 2);
  memcpy(frameData + 4, &analogPins[5], 2);
  memcpy(frameData + 6, &analogPins[6], 2);
  // write 3rd CAN frame to serial
  SendCANFrameToSerial(3202, frameData);
  // build 4th frame, this is a text extension frame
  // only send once at 1000 loops
  if (textCounter == 0)
    SendTextExtensionFrameToSerial(3203, "egtLevel");
  else if (textCounter == 1000)
    //SendTextExtensionFrameToSerial(3203, "Tomorrow's forecast: Lots of sun and 30 degrees centigate");
  else if (textCounter == 2000)
    //SendTextExtensionFrameToSerial(3203, "Now Playing: Insert your favorite song info here");
  else if (textCounter == 3000)
    //SendTextExtensionFrameToSerial(3203, "Message from Arduino: All systems running at nominal efficiency");
  Serial.write(serialBlockTag, 4);
  // CAN frame payload
  Serial.write(frameData, 8);
void SendTextExtensionFrameToSerial(unsigned long canFrameId, const char* text)
  if (text)
    const byte textExtensionBlockTag[4] = { 0x55, 0x33, 0x22, 0x11 };
    Serial.write(textExtensionBlockTag, 4);
    // text payload
    Serial.write(text, strlen(text) + 1);
void ReadIncomingSerialData()
  while (Serial.available() > 0)
    // little bit of extra effort here, since especially Bluetooth connections
    // may leave unsent/received data in internal buffer for a long time
    // therefore, we cannot be sure that incoming byte stream really starts at
    // where we expect it to start.
    // read one byte from serial stream
    incomingFrame[incomingFramePos++] = Serial.read();
    // check the first incoming bytes tag (0x44, 0x33, 0x22, 0x11)
    if (incomingFrame[0] != 0x44)
      // first incoming byte is not 0x44,
      // the tag at the beginning of the frame does not match, this is an invalid frame
      // just zero the incomingFrame buffer and start expecting first byte again
      memset(incomingFrame, 0, 17);
    if (incomingFramePos >= 17)
      // frame complete, process it
      ProcessIncomingFrame(incomingFrame);
      // zero the incomingFrame buffer and start expecting first byte again
void ProcessIncomingFrame(const byte* frame)
  // first four bytes contain set value frame separator bytes, always 0x44,0x33,0x22,x11
  // check that first 4 bytes match the tag
  if (frame[0] != 0x44 ||
      frame[1] != 0x33 ||
      frame[2] != 0x22 ||
      frame[3] != 0x11)
    // frame tag does not match, wait for another frame
    return;
  // next four bytes contain set value CAN frame id in little endian form
  unsigned long canFrameId = 0;
  memcpy(&canFrameId, frame + 4, 4);
  // next 8 bytes are the frame data
  // last byte is check byte calculated as sum of previous 13 bytes (ignore overflow)
  byte checkByte = 0;
  for (int i=0; i<16; i++)
    checkByte += frame[i];
  if (frame[16] == checkByte)
    // checksum match, this is a valid set value-frame:
    // the frame payload data is in frame + 8 bytes
    HandleIncomingSetValueFrame(canFrameId, frame + 8);
void HandleIncomingSetValueFrame(unsigned long canFrameId, const byte* frameData)
  if (canFrameId == 3201)
    memcpy(&digitalPins, frameData, 2);
    memcpy(&analogPins[0], frameData + 2, 2);
    memcpy(&analogPins[1], frameData + 4, 2);
    memcpy(&analogPins[2], frameData + 6, 2);
    // write digital pins
    for (int i=0; i<13; i++)
      digitalWrite(i + 1, (digitalPins & (1 << i)) ? HIGH : LOW);
    analogWrite(0, analogPins[0]);
    analogWrite(1, analogPins[1]);
    analogWrite(2, analogPins[2]);
#endif
  else if (canFrameId == 3202)
    memcpy(&analogPins[3], frameData + 0, 2);
    memcpy(&analogPins[4], frameData + 2, 2);
    memcpy(&analogPins[5], frameData + 4, 2);
    memcpy(&analogPins[6], frameData + 6, 2);
    analogWrite(3, analogPins[3]);
    analogWrite(4, analogPins[4]);
    analogWrite(5, analogPins[5]);
    analogWrite(6, analogPins[6]);
#endif
I don’t see your egtRead variable change anywhere after initialization.
Same guy. Still not getting this EGT to work. When I serial print the egtlevel in the loop, its updating every time. Not showing on realdash at all.
 * RealDash CAN protocol example. Simplified.
 * Author: Jani Immonen, optimized version.
unsigned int FUEL = A2, DRIVE = A1, BOOST = A0;
// Pin assignments for HW-550
int thermoDO = 48;  // SO (Serial Data Out)
int thermoCS = 46;  // CS (Chip Select)
int thermoCLK = 44; // SCK (Serial Clock)
unsigned int rpm = 0, kpa = 992, tps = 965, clt = 80, textCounter = 0;
unsigned int digitalPins = 0, analogPins[7] = {0};
int egtLevel = 0; // Moved egtLevel declaration here
byte incomingFrame[17] = {0};
void setup() {
    for (int i = 1; i < 14; i++) {
      pinMode(i, OUTPUT);
  #endif
  // Initialize peripherals
  pinMode(27, OUTPUT);
  digitalWrite(27, LOW);
  pinMode(29, OUTPUT);
  digitalWrite(29, HIGH);
  pinMode(22, OUTPUT);
  digitalWrite(22, LOW);
  pinMode(50, OUTPUT);
  digitalWrite(50, HIGH);
  pinMode(52, OUTPUT);
  digitalWrite(52, LOW);
  delay(1000);
  lcd.clear();
  digitalWrite(47, LOW);
void loop() {
  egtLevel = thermocouple.readFahrenheit(); // egtLevel is updated here
  if (++rpm > 10000) rpm = 500;
  if (++kpa > 2500) kpa = 10;
  if (++tps > 1000) tps = 0;
  if (++clt > 230) clt = 0;
  if (++textCounter > 4000) textCounter = 0;
  delay(150);
void ReadDigitalStatuses() {
    digitalPins = 0;
      if (digitalRead(i) == HIGH) digitalPins |= (1 << (i - 1));
  #endif
void ReadAnalogStatuses() {
    for (int i = 0; i < 7; i++) {
  #endif
void SendCANFramesToSerial() {
  byte frameData[8];
  memcpy(frameData, &egtLevel, 2); // Now egtLevel is global, no more error
  if (textCounter == 0) SendTextExtensionFrameToSerial(3203, "egtLevel");
void SendCANFrameToSerial(unsigned long canFrameId, const byte* frameData) {
  const byte serialBlockTag[4] = {0x44, 0x33, 0x22, 0x11};
void SendTextExtensionFrameToSerial(unsigned long canFrameId, const char* text) {
  if (text) {
    const byte textExtensionBlockTag[4] = {0x55, 0x33, 0x22, 0x11};
void ReadIncomingSerialData() {
  while (Serial.available() > 0) {
    if (incomingFrame[0] != 0x44) {
    if (incomingFramePos >= 17) {
void ProcessIncomingFrame(const byte* frame) {
  if (memcmp(frame, "\x44\x33\x22\x11", 4) != 0) return;
  unsigned long canFrameId;
  byte checkByte = 0;
  for (int i = 0; i < 16; i++) checkByte += frame[i];
  if (frame[16] == checkByte) HandleIncomingSetValueFrame(canFrameId, frame + 8);
void HandleIncomingSetValueFrame(unsigned long canFrameId, const byte* frameData) {
  if (canFrameId == 3201) {
      for (int i = 0; i < 14; i++) {
    #endif
  } else if (canFrameId == 3202) {
    memcpy(&analogPins[3], frameData, 2);
    #endif
realdash_can_example3.22.xml (5.7 KB)
This is my sketch and the xml im using in the app. Boost, drive, fuel pressure, all the digital switches/relays are working great.
For reference
Serial.print("EGT (°F) Sent to RealDash: "); Serial.println(egtLevel);
Only thing I can see is that variable egtLevel is an ‘int’ and all other values are ‘unsigned int’. It should not make any difference, but depending on the hardware it in theory could.
Otherwise your code and XML seems fine.
Im going to map the egtlevel to pwm and read that back. Hopefully that gets me something.
