@realdashdev the Mazda canbus I am working on is big endian, but the results I got using startbit trialling both endians left me a little confused; both bits were set, so should have resulted in 3, which the little endian version did, but the big endian version gave me 1. Does RealDash amend the direction of the startbit location based upon the endianness i.e. aligned with the DBC format?
RealDash
value name=“MZ: ccs_le” startbit=“1” bitcount=“2” endianess=“little” signed=“false”
value name=“MZ: ccs_be” startbit=“2” bitcount=“2” endianess=“big” signed=“false”
@realdashdev noted, but perhaps it should then be clarified the process of uploading a DBC file to Garage for conversion to XML will not work for big endian unless its single bits
