Hello,
Adapter could not be found from RealDash supported adapters.
Anyhow, adapter is from Van Kronenburg KMS pages:
Basically what it does converts CAN to Bluetooth.
I contacted to KMS and luckily i was able to get *.DBC file from them.
Seems i can not add file here because of supported files, and i could not convert file to xml.
So instead of trying to convert it, i open it with notepad++ and copy & paste it here, i hope it is ok…
File md35.dbc begin ****
VERSION “HIPBNYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY/4/%%%/4/'%**4YYY///”
NS_ :
NS_DESC_
CM_
BA_DEF_
BA_
VAL_
CAT_DEF_
CAT_
FILTER
BA_DEF_DEF_
EV_DATA_
ENVVAR_DATA_
SGTYPE_
SGTYPE_VAL_
BA_DEF_SGTYPE_
BA_SGTYPE_
SIG_TYPE_REF_
VAL_TABLE_
SIG_GROUP_
SIG_VALTYPE_
SIGTYPE_VALTYPE_
BS_:
BU_:
BO_ 40 md35_1: 8 Vector__XXX
SG_ OilPressure : 55|16@0+ (1,0) [0|1250] “KPA” Vector__XXX
SG_ RPM : 7|16@0+ (10,0) [0|20000] “Rev/Min” Vector__XXX
SG_ Coolant_Temp : 23|8@0+ (1,-20) [-20|135] “Deg C” Vector__XXX
SG_ Intake_Temp : 31|8@0+ (1,-20) [-20|135] “Deg C” Vector__XXX
SG_ Boost_Pressure : 39|16@0+ (1,0) [0|2000] “KPA” Vector__XXX
BO_ 41 md35_2: 8 Vector__XXX
SG_ CrankSignal : 47|8@0+ (1,0) [0|0] “Teeth_per/rev” Vector__XXX
SG_ EGT_2 : 39|8@0+ (5,0) [0|1250] “Deg_C” Vector__XXX
SG_ EGT_1 : 31|8@0+ (5,0) [0|1250] “Deg_C” Vector__XXX
SG_ Supply_Voltage : 23|8@0+ (0.25,8) [8|22] “Volt” Vector__XXX
SG_ Load_MAP : 15|8@0+ (0.1,0) [0|15.9] “Load_Site” Vector__XXX
SG_ Load_TPS : 7|8@0+ (0.1,0) [0|15.9] “Load_Site” Vector__XXX
SG_ Acceleration : 63|8@0+ (0.1,-10) [-10|10] "%per/rev" Vector__XXX
SG Gear : 55|8@0+ (1,0) [0|13] “Nr” Vector__XXX
BO_ 42 md35_3: 8 Vector__XXX
SG_ Lambda2_Status : 63|8@0+ (1,0) [0|0] “” Vector__XXX
SG_ Lambda1_Status : 55|8@0+ (1,0) [0|0] “” Vector__XXX
SG_ Lambda2 : 47|8@0+ (0.005,0.65) [0.65|1.455] “Lambda” Vector__XXX
SG_ Lambda1 : 39|8@0+ (0.005,0.65) [0.65|1.455] “Lambda” Vector__XXX
SG_ Correction_Inj_grp_1 : 23|16@0- (0.1,0) [-300|600] “%” Vector__XXX
SG_ Injection_grp_1 : 7|16@0+ (0.001,0) [0|65] “Ms” Vector__XXX
BO_ 43 md35_4: 8 Vector__XXX
SG_ Ignition : 55|16@0+ (-0.1,54) [0|0] “DEG adv.” Vector__XXX
SG_ Correction_Ignition : 39|16@0+ (0.1,0) [-300|600] “%” Vector__XXX
SG_ Correction_Inj_grp_2 : 23|16@0- (0.1,0) [-300|600] “%” Vector__XXX
SG_ Injection_grp_2 : 7|16@0- (0.001,0) [0|65] “Ms” Vector__XXX
BO_ 44 md35_5: 8 Vector__XXX
SG_ Aux_Out_2 : 8|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Aux_Out_3 : 9|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ FuelPump : 10|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Aux_Out_1 : 11|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Lambda_Control : 12|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Lambda_Error : 13|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Boost_Controll : 14|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Sensor_Supply : 15|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Power_Shift_Input : 0|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Launch_Input : 1|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ OverRun : 21|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Boost_Limit : 22|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Soft_Rpm_Limit : 23|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Idle_Pwm : 39|8@0+ (0.5,0) [0|100] “%” Vector__XXX
SG_ Boost_Pwm : 47|8@0+ (0.5,0) [0|100] “%” Vector__XXX
SG_ Baro_Pressure : 55|16@0+ (1,750) [750|1200] “Mb” Vector__XXX
SG_ Als_active : 2|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Traction_Ctrl : 3|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Speed_Limiter : 4|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Pit_Limiter : 5|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ Traction_Main_SW : 20|1@0+ (1,0) [0|0] “” Vector__XXX
BO_ 45 md35_6: 8 Vector__XXX
SG_ kmh : 7|16@0+ (0.01,0) [0|0] “kmh” Vector__XXX
SG_ LaunchRpm : 23|16@0+ (1,0) [0|0] “rpm” Vector__XXX
SG_ wheelSlip : 39|16@0+ (0.1,0) [0|0] “%” Vector__XXX
SG_ Var_ALS : 55|8@0+ (1,0) [0|0] “%” Vector__XXX
BO_ 143 md35_7: 8 Vector__XXX
SG_ Speed_Front_Cal m1 : 40|16@1+ (0.1,0) [20|0] “mm/p” Vector__XXX
SG_ Speed_Rear_Cal m1 : 24|16@1+ (0.1,0) [20|0] “mm/p” Vector__XXX
SG_ mode_1 M : 56|8@1+ (1,0) [0|0] “” Vector__XXX
SG_ PH_Inj_Type m5 : 48|8@1+ (1,0) [0|0] “” Vector__XXX
SG_ PH_Phase1 m6 : 40|8@1+ (0.04,0) [0|0] “Sec” Vector__XXX
SG_ PH_Phase2 m5 : 32|8@1+ (0.02,0) [0|0] “Msec” Vector__XXX
SG_ PH_Peak_Current m5 : 40|8@1+ (0.08,0) [0|0] “Amp” Vector__XXX
SG_ PH_Phase3 m5 : 24|8@1+ (2,0) [0|0] “Usec” Vector__XXX
SG_ PH_Hold_Current m5 : 8|8@1+ (0.016,0) [0|0] “Amp” Vector__XXX
SG_ PH_TempHoldCurrent m5 : 0|8@1+ (0.016,0) [0|0] “Amp” Vector__XXX
SG_ PH_TempHoldCurrentTime m6 : 48|8@1+ (0.02,0) [0|0] “Msec” Vector__XXX
SG_ PH_Demag_mode m5 : 16|8@1+ (1,0) [0|0] “” Vector__XXX
SG_ Injector_Test_Nr m4 : 48|8@1+ (1,0) [0|0] “Inj_NR” Vector__XXX
SG_ Injector_Test_Time m4 : 40|8@1+ (1,0) [0|0] “Msec” Vector__XXX
SG_ SegInj1AtOutput m2 : 48|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj2AtOutput m2 : 40|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj3AtOutput m2 : 32|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj4AtOutput m2 : 24|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj5AtOutput m3 : 48|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj6AtOutput m3 : 40|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj7AtOutput m3 : 32|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj8AtOutput m3 : 24|4@1+ (1,0) [0|0] “” Vector__XXX
SG_ SegInj1UseGroup m2 : 54|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj2UseGroup m2 : 46|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj3UseGroup m2 : 38|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj4UseGroup m2 : 30|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj5UseGroup m3 : 54|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj6UseGroup m3 : 46|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj7UseGroup m3 : 38|1@1+ (1,1) [0|0] “” Vector__XXX
SG_ SegInj8UseGroup m3 : 30|1@1+ (1,1) [0|0] “” Vector__XXX
BO_ 144 md35_8: 8 Vector__XXX
SG_ InjectionTimeGroup1 m1 : 15|16@0+ (0.002,0) [0|0] “Msec” Vector__XXX
SG_ InjectionTimeGroup2 m1 : 31|16@0+ (0.002,0) [0|0] “Msec” Vector__XXX
SG_ Mode M : 7|8@0+ (1,0) [0|0] “” Vector__XXX
SG_ InjectionStartPulsIndirect m2 : 15|16@0+ (0.002,0) [0|0] “Msec” Vector__XXX
SG_ InjectionStartPulsDirect m3 : 15|16@0+ (0.002,0) [0|0] “Msec” Vector__XXX
CM_ SG_ 143 Speed_Front_Cal “”;
CM_ SG_ 143 mode_1 “mode signal must be 1 hex”;
VAL_ 42 Lambda2_Status 0 “No Errors” 1 “Sensor To Cold Signal Valid” 2 “Sensor To Hot Signal Valid” 9 “WarmUp Fase Singnal Invalid” 4 “WarmUp Fase Singnal Valid” 8 “Temperature error Signal Invalid” 24 “Heater Ground Open” 40 “Sensor not Connected” 56 “sensor wires open” 72 “Unknown error or no sensor selected” ;
VAL_ 42 Lambda1_Status 0 “No Errors” 1 “Sensor To Cold Signal Valid” 2 “Sensor To Hot Signal Valid” 4 “WarmUp Fase Singnal Valid” 9 “WarmUp Fase Singnal Invalid” 8 “Temperature error Signal Invalid” 24 “Heater Ground Open” 40 “Sensor not Connected” 56 “sensor wires open” 72 “Unknown error or no sensor selected” ;
VAL_ 44 Aux_Out_2 0 " " 1 “Aux 2 On” ;
VAL_ 44 Aux_Out_3 0 " " 1 “Aux 3 On” ;
VAL_ 44 FuelPump 0 " " 1 “FuelPump On” ;
VAL_ 44 Aux_Out_1 0 " " 1 “Aux 1 On” ;
VAL_ 44 Lambda_Control 0 " " 1 “Lambda Controll Active” ;
VAL_ 44 Lambda_Error 0 “No Lambda Error” 1 “Lambda Error” ;
VAL_ 44 Boost_Controll 0 " " 1 “Boost Control Active” ;
VAL_ 44 Sensor_Supply 0 " " 1 “Sensor Supply Error” ;
VAL_ 44 Power_Shift_Input 0 " " 1 “Power SHift Input Active” ;
VAL_ 44 Launch_Input 0 " " 1 “Launch Input Active” ;
VAL_ 44 OverRun 0 " " 1 “Overrun FuelCut Active” ;
VAL_ 44 Boost_Limit 0 " " 1 “Boost Limiter Active” ;
VAL_ 44 Soft_Rpm_Limit 0 " " 1 “Soft RPM Limiter Active” ;
VAL_ 44 Als_active 0 " " 1 “Als_active” ;
VAL_ 44 Traction_Main_SW 0 “Traction Ctrl Disabled” 1 “traction Ctrl Enabled” ;
VAL_ 143 PH_Inj_Type 0 “userdefined” 1 “Default_1_Injector” 2 “Default_2_Injectors” 3 “Default_3_Injectors” 4 “Default_4_Injectors” 5 “Default_5_Injectors” ;
VAL_ 143 PH_Demag_mode 0 “slow” 1 “Fast” ;
File md35.dbc end ****
Br.
Henri
