Hello. using SLCAN and RD 2.5.0 on windows it crashes instantly on wakeup of the CAN. Same situation if im using the “monitor”. Savvycan sees and logs can just fine.
Adapter is a WeAct usb2canFD
when the CAN monitor is turned on, the application closes urgently.
no, it freezes here. And you can only get it back by gooing to task manager and killing it. It also do it on the dash page, no monitor. allmost like it can’t handle the CAN speed on the newer GM (2017)
I will check. If I remember right, the SLCAN is a text based protocol and may not be the best one for fast connections. It could also send something that RD does not parse correctly.
Okay, Do you know if i can flash something on the Weact so its better for RealDash? Savvycan works beautifully with it.
Don’t know, I’m not that familiar with these adapters.
I may have found a issue with SLCAN parsing with extended frames. I will push 2.5.1 pre-release 5 later today.
Thank you, How can i get a copy? And do you want a Log from savvycan to check?
That could be helpful, please send to contact@realdash.net. I will then send you a link to pre-release version.
Do you know when you gonna release the 2.5.1 for linux / widows? I have a event comming up and wuld love to run realdash..
Hope to release 2.5.1 within a next few days.
