I’m using Realdash in a windows 10 virtual machine with virtualbox.
I’m doing that because I want to use a specific screen resolution for dash developpement (1920x720) and with virtual box it’s easy with the command vboxmanage controlvm “machine name” setvideomodehint 1920 720 32
(while searching for solution, I found that you can set specific resolution to real dash in the settings so I think that will be a better way to do it. Anyway…)
When I open the MKV premium dashboard and click on left of the cluster to display the GPS, my virtual machine freeze completely! I can’t even send atl+ctrl+delete. I have to power cycle the virtual machine and start real dash again.
On the default dashboard, when I click on the map, it lags for 10 seconds and then it’s ok.
If I take the 720RD premium dashboard, same issue. Virtual machine freeze and I have to reboot it.
If I go to settings and select “Where is my car” the map partially open up and then everything freeze again.
Any idea what could be causing this? It’s clearly related to the map/gps
