Realdash does not save OBD2 configuration
When turning on the ignition, OBD2 connects. When turning off the ignition again and turning it on again, it seems to lose the connection. It continues flashing but no longer shows information such as temperature and battery voltage. If you turn off the key and wait for the panel to turn off completely after the timing, then it stops flashing. If you turn on the key again, it reads the PID and connects normally. Is there a configuration in Realdash that delays OBD2 so that it does not connect after turning off the ignition and turning it back on? Is it possible to configure OBD2 to connect automatically in any situation, short or long after the ignition starts? Is there a more precise OBD2 configuration?
