Why does realdash not output sound in windows sound effects
Do you mean the sound effect that is triggered by action? Will check that on Windows.
Exactly that, if you can check it please
I have the same issue. Works on iOS
I have the same issue Windows 10.
Alright, will check and fix.
The sound playback did work for me, but noticed something that may be the issue for you also.
On my testing session, the RealDash ‘Device Volume’ input was set to 0- thus no sound. Added a slider and attached to device volume and sound effects started playing.
Windows Universal platform does not allow to adjust actual device volume. Se RealDash uses its own internal input for that and just multiplies all playback volume with that.
I think what has happened is that default value in RealDash for that input is 0. Will change that to 100.
OK thanks, I’ll test it later
