I have been using RealDash for a couple of weeks, until yesterday everything worked just fine. Today I started the app and it crashed directly during start. It gets to the point were it show the RealDash logo and then it disappears.
It seems like the app updated automatically. I have tried the following things to fix the problem.
Cleared app cache, no success
Cleared app data, no success
Uninstalled the app and reinstalled from play store, no success
Complete reset of tablet (android 9.0) only configured WiFi and Play store account
Reinstalled RealDash from the play store, no success
I have a similar tablet with RealDash version 1.8.4 and it works like a charm. Auto update is disabled on that Tablet.Is there a way of installing a previous version of RealDash. Are there any settings that may have to be changed for this latest version to work?
I have purchased the full version as well as the Bavarian Powerhouse dashboard.
I am a great fan of your RealDash solution and hope you, me or we can fix this problem. Thanks! Bram
I’m having the same issue after the February 1st update when using my custom dash, but it runs fine with the Classic S2000 skin. Is it possible the issue lie in the custom triggers? Happy to share my Rd file if it helps
Btw I’m running a Samsung Tab S6 LTE SM-T865, running Android 10 Samsung UI 2.5. I was beta tester for app, tried rolling back from beta, still the same issue. Hope this helps! Awesome app! Use it as my main dashboard in my van.
I found the problem on your .rd file. The problem was that your dash file contains another dash file as an image asset. The new, faster dashloader got confused by that and deduced that dash file must be corrupted.
I am going to push a 1.8.8 hotfix very soon. It will be able to load your dash file regardless.
New version will not load it so it no longer shows on your image assets. But you may want to go thru your assets anyways as your dash file is very large and probably has unused assets in it.
I’ll definitely give it a scrub. Got the update, it’s working now! Thanks! The only other ongoing issue is Spotify is still finicky to show, but the easy fix has been going in to settings, and switching between Spotify and Google music. Thanks again!!
Still the same with 1.8.9 beta. Sorry for my delayed response. Also question, how do you access the assets other then images? Slimming the file down, seeing if that fixes it too.
I found a problem that if music player is started after the RealDash, the music tracking may not start. This is fixed on 1.8.9-beta2. Don’t know if this has been the reason for music tracking issues you have been experiencing, but its worth a try.
