Hi folks, So I have a EMU Black and the Can-BT adapter which I connect my phone to and run RealDash on it.
I would like to make it a bit more seamless, but using a 2nd phone is not ideal due to few reasons. (too big, also my last phone’s display cracked when the car was parked outside due to heat)
I want to keep the interior as stock as possible.
Can I run RealDash on some kind of a SBC and connect it to a small display? (2 or 3 inch display which I can place inside the stock instrument cluster and display 4 or 6 values)
I assume this can be done via a SBC like R-Pi with Android but maybe RD has a more optimized Linux distro?
If not, what do you recommend? I also don’t have space for an Android headunit (again to maintain stock interior)
Thank you
