Realdash online manual?
I am very new to RD and am struggling editing gauges. Is there an online manual?
Not really, you need to experiment on most cases.
There are couple of videos about the basics at the end of this page:
RealDash | Manuals & Tutorials
OK thanks. ill take a look.
I just want to edit some standard gauges for new sources and values initially.
Is there a simple way to delete a gauge? EDIT. Found it…pull up and pull down menus…
Yes, very simple.
  • In edit mode, select the gauge(s)
  • Press ‘DEL’ on your keyboard.
  • Accept the ‘Are you sure?’ popup.
If you are editing on touch screen without keyboard:
  • Open bottom menu and tap ‘Context Menu’
  • On context menu select Edit->Delete
We recommend that all dashboard editing is done in Windows, Linux or Mac version of RealDash running on desktop computer. Its just too clumsy to do on touch screen.
sorry last question.
Using the aux channels on speeduino. In the source options are they CAN 1 and CAN 2? I am running oil and fuel pressure sensors in as aux channels
Hopefully someone with Speeduino can help you with that. We do not have one.
