- 1.7.3 released 17.4.2020
New:
- EasyEcu 3+ is now supported (http://www.ottomotive.pl)
- New input value: Simulated oil pressure.
- Color slider now affects indicators and text.
- Added separate input for front fog lights.
- New engine parameter: Idle RPM.
- Look’n Feel shows color adjust preview.
- Android: Added ultrawide screen scale option (haxxor).
Fixes:
- Color slider values can now be set with actions.
- Fixed some datalog files not showing speed on playback.
- Float values can now be entered without leading zero.
- Dashboard variants are listed in gallery dash info popup.
- Reduced playback latency on sound effects.
- User zoom level is now saved for all dashes.
- Fixed crash on input mapping popup when mapping contained unknown custom value.
- Enginebits moved to Engine category.
- Fixed dynamic color setting not saving or applying to most color components.
- Fixed removal of data multicast values.
- Android: Fixed connection issue with ME442 PnP.
- Android: Added support for USB serial VID0x0483/PID0x5740.
- MaxxECU: restored Lambda to its original source.
- MaxxECU: Added fuel pressure channel.
Notes:
The ‘Ultrawide Aspect Fix’ option (Settings->Application->2nd page) force scales the dashboard into ultrawide screens. This may become handy when Android does not recognize the real screen size and reports invalid resolution. This is a hack, and dashboard editing is disabled when this option is active.
