- 1.7.6 released 5.6.2020
New:
- Speed limit warning notification.
- New action: Reset history mode of all gauges in page.
- Added Skip Tutorial option on startup.
- Android: Some Bluetooth LE serial devices are now supported.
Fixes:
- Speeduino: Fixed signed value handling.
- Speeduino: Lambda is now set per incoming AFR.
- Speeduino: Added support for VSS data.
- Improved reliability of ME221 connection.
- Multicast settings now show amount of sent/received data correctly.
- Multicast clients now reset received values if connection is lost.
- Multicast values are sent when not used by dashboard.
- Settings import/export now contains global triggers and actions.
- Added E100 as fuel type.
- Gauge history modes are now reset when new connection is made.
- OBD2: Fixed reconnect on some vehicles after ignition off/on.
- Android: Added legacy file access mode for API29.
