- 1.7.8 released 10.7.2020
New:
- OBDLink OBD2 adapters can now be used as direct CAN adapters
- OBD2: Added config for Toyota GT86
- OBD2 monitor has command history (arrows up & down)
- CAN Adapters: Added some predefined CAN descriptions
- New fuel type, E10, and optional E100
- Text to time formatting options added to Look’n Feel
- New racetrack: Red Ring, Russia
Fixes:
- CAN and OBD2 monitor data can now be scrolled with mouse wheel
- Stopwatch now uses default font if font is not set
- Stopwatch background is now correctly drawn behind the text elements
- Android: Fixed internal music player artist info
- Fixed problem in saving profile tripmeter value
- Fixed some gauges not moving with arrow keys in edit mode
- OBD2: Custom XML header support improved
Notes:
RealDash 1.7.8 supports OBDLink MX, MX+ and SX adapters as direct CAN adapters. To setup the connection select ‘Adapters (CAN/LIN)->OBDLink CAN adapter’ as connection type.
