- 1.8.0 released 18.9.2020
New:
- Speeduino serial0 updated to August 2020 firmware.
- Custom intro images now use fade in between.
- Enum can now be used with OBD2-XML files.
- Local time and ISO time now have internal values as seconds since midnight that can be used with triggers.
- OBDLink adapter as CAN device is now able to read and clear error codes.
- New voice command: Open Spotify.
- OBD2: Added profile, GM LS (typical).
Fixes:
- Range calculation uses more recent consumption data.
- Instant and average fuel consumption now uses the correction factor in same way.
- DashTalk UTF8 support fixed.
- Body Electronics->Fuel Level has some additional averaging filtering.
- Weather info is updated faster on app startup.
- Fuel Pressure input moved to ‘Engine’ category.
- Reduced memory fragmentation, performance increase on low end devices.
- History mode gauges are updated when on another page.
- Queued speech is now canceled when speech recognition is activated.
- Longest trip is no longer cumulative.
- Fixed speech recognition starting from button presses.
- Link: Fixed short and long datastream to match latest G4+ spec.
- OBD2: Fixed reply parsing when request is longer than 4 characters.
- OBD2: Fixed reply parsing when multiple ECUs reply to the request.
Notes:
If you are using custom XML with OBD2 connection you may need to update the ‘conversion’ for the values when command ‘send’ is longer than 4 characters. Sorry for the inconvenience.
