- 1.8.2 released 27.10.2020
New:
- New edit options: Page->Scale All Up/Down (ctrl+8 and ctrl+9).
- New input: Fuel Cut Active.
- New calculated values: Fuel Consumption (Liters or gallons per hour) and Current Gear Ratio.
- XML ‘enum’ can now use range of values.
- New setting: Vehicle max speed and corresponding autoscaling option.
Fixes:
- CAN monitor font size is increased on high res screens.
- RealDash CAN protocol can now write GPS location to ids 307 and 308.
- Fixed a crash in CAN Monitor.
- Fuel consumption correction factor can now be set to 0.
- Space evenly edit command now works with two selected gauges.
- Fixed hang in intro if one custom image is set and file not available.
- FH4: MaxRPM is now set from telemetry stream.
- FH4: Pedal positions are now scaled correctly to 0-100.
