RealDash version 2.4.0
  • 2.4.0 released 7.6.2024
New:
  • Custom value mapping is now exported/imported with garage settings.
Fixes:
  • Value Changed trigger now works with text values.
  • Fixed parsing error on XML files when conversion referred to other custom values.
  • AM/PM is now correct around noon and midnight.
  • Fixed occasional crash on multicore dash loading.
  • Units attribute is now updated on custom values when re-importing XML.
  • Fixed issues with CSV datalog files with value names containing commas.
  • Service distance and hours are not triggered immediately on fresh install.
  • OSX: Fixed some window resize crashes.
  • OSX: Bluetooth permission is now asked from the user.
  • RPi: GPIO is not initialized if not used by current dashboard.
Have 99 acura tl J32A1 engine using my elm 327 v2.1 diagnostic scanner will i be able to.use that along with my android fir adding some tunes
Assuming you mean changing your vehicle ECU parameters, I’d say no. RealDash does not include any functionality to tune your vehicle.
Thank you for your time would you know of an app that i can
