Thank you. That worked. I was looking in input & values. I had also checked look and feel but was pressing the select assets button instead of video source button.
Is there a way to make RealDash stop asking for permission to use each of the devices hooked to my headunit? I have a game controller, a USB stick, and a TPMS dongle. Everytime I start the car RealDash pops windows up for each asking permisson.
Using an Android TS10 13.1" headunit with Android 11. Realdash given full permissions in settings.
Hi any update for holley system to connect directly with usb.
Unfortunately no, permission is asked by Android everytime USB device is disconnected/connected. Permissions should stay if devices are left connected.
Lets keep this thread specific to 2.4.3 features and issues.
But no, Any Holley device will need a CAN connection.
Maybe the developer mode of the device can bypass it being asked every time but I’m not too sure.
Yes, the devices are left connected. RealDash asks permission for each device, everytime it loads. Even a USB hub. It only started doing this with the latest version. If there could be a way to just have RealDash auto-accept, or just disable the USB functionality. Either way would be great.
Having to hit “ok” or “cancel” 3 times before doing anything each time I turn my car on is super annoying…
Yes, I’m working on an update that would not ask permission for anything but serial devices and cameras.
Yea, I tried that. No luck.
Perhaps a variable that saves in the config whether it’s been allowed or accepted, so it doesnt have to ask each time.
idk if that’s doable, but it would be nice
awesome… anyway to make it ask only once? Kind of like there is an option to auto shutdown bluetooth on exit, ect. I think it sees my USB hub and game controller as a serial device.
If there is such an opportunity to add the voltage of the device?
I have 2 devices, both of them have version 2.4.4 installed. 1 of the device, everything works normally 2- When the device turns on some indicators, the system shuts down and does not turn on. The same thing happened when I upgraded to version 2.4.3. Fix the system, everything is normal, but today the system shuts down again on some indicators. I am experiencing the same situation as when I first upgraded to version 2.4.3.
Alright, seems like the JPEG SIMD bug is back. Will publish 2.4.4-2 soon.
