RealDash version 2.6.4
2.6.4 released 6.3.2026
New:
  • Support for Spitronics Mercury 3 and Badger.
Fixes:
  • Mask image preventing line rendering on autoscaling.
  • New dashboard template having 0 autoscaling sweep angle.
  • Autoscrolling text respects its container clipping area.
  • Android: Waze app now launches correctly when selected as navigation app.
Thanks. I updated the app but it still doesn’t work. I get the same error " app not installed ". Maybe you could also check with some other members.
Hi ..What I meant was the Waze app still doesn’t work after the update.
Odd, I did test it on my Android test device.
Previously, I’ve had no issues when updating RealDash; it has always found the DashBox without any problems. However, after the latest update, I can’t establish a connection anymore. The DashBox is connected via USB.
The last working update I did was last autumn, I think it was around August 2025
Or are the previous updates available somewhere?
Any ideas what has changed?
Connection detected in CAN monitor, but data fails to reach the dashboard. This worked correctly in the earlier version
Hi. I have also noticed apart from the WAZE app not being able to select as an option for navigation ,the odometer also does not show the correct DTE (distance to Empty) in fact it keeps changing from eg: 300km to 45km regardless I drive the car or I just start and park it.
For DashBox USB connection, you need to add at least 4 second delay for the connection. This can be done from RealDash USB connection settings with ‘Advanced’ button.
I may have found an issue with Waze launch that is Android version dependent. Fix should be in next release.
As for the displayed Range, is your received Fuel Consumption somewhat correct?
Hi, could you give me instructions on where to add the connection delay? I can’t find the place in RealDash where the delay can be set. I’m using the Windows version of RealDash.
I have a RealDash license, but the Windows .exe version does not appear in my My Downloads page. I can only see the other versions (Android, macOS, Linux, ARM, etc.).
Could you please add the Windows 64‑bit version (RealDash Windows .exe) to my account?
Put a value of 4500 to this box.
Unfortunately Windows version can only be distributed via Microsoft Store.
Found a solution to the problem. Also had to select ‘Yes’ here
Hi. Sorry for the delay in response. Yes Fuel consumption is more often correct than not .
