RealDash version 2.6.5
2.6.5 released 22.4.2026
New:
  • Added calculated input for Density Altitude.
  • Rotate value up/down action now has optional comma separated value set.
  • Multiple new detected racetracks.
Fixes:
  • CAN XML initialValue attribute.
  • SLCAN silent mode now works.
  • Input select popup not accepting ‘GPIO’ or ‘Other’ categories.
  • Non-zero value can now be set to ‘value change into’ type of trigger.
  • Startup crash when input value name was used in global action.
  • Datalog playback demo mode option moved to ‘Data Source’.
  • Added ‘Transmission’ category into Debug Data View.
  • Improved multithreading support for performance and reliability.
Android got quick 2.6.5-2 release as we were finally able to catch the random crash when entering CAN Monitor. Issue was present in Android version only. This is now fixed in 2.6.5-2
On the new version, when the source is set to None, all gauges freeze at their last value—for example, the speed will remain at 100.
Alright, will check that
Hi everyone,i’m looking for a realdash skin for my Alfa Romeo Gtam but it’s for a diesel engine.I like the Gtam style graphics. Can everyone help me?
Is there any way to have a version save or a roll back on the xml files? I have overwritten mine when testing and lost work. Also, thank you for making changes so fast.. Had a question about the Density Altitude sensor you created for me. What do I use to input my sources to the sensor? I will be using one of these BME280 Environmental Sensor on a PI 5 i can use I2C or SPI to get it into the Linux environment.
please forgive me for thinking about compass (android). to use on boats
How do we see what is being calculated in calculated sensors? Is this posted somewhere, example boost I know is can use Formula: (\text{Boost Pressure} = \text{MAP Reading} - \text{Atmospheric Pressure}) ?
You can already make a compass from GPS heading.
