Greetings, I am very interested in the new dashboard update, what I want to ask is if I make a purchase on the Play Store and then I uninstall it and then I install the version with the home button, will I still get the full version?
I found a way to assign a button to Debug in setting that is very useful. I used a trigger to access it. If there a way we can create a trigger to go to a connection setting? This would help make it faster when I’m developing?
Hello,
Is it possible that since the update (or perhaps even before, since it’s been a while since I last updated…) the calculated variable “Data Update Rate” is no longer being updated and remains at 0 all the time, despite a Bluetooth CAN connection (OBDLink LX)?
Thank you for your help, as this is causing a major issue for me.
I downloaded the Home APK, and when I click on the top, a menu appears on the left. I want to add buttons to the bottom so that pressing those buttons opens the menu. How can I do that?
Here’s something else that didn’t happen before, but I’m not sure if it’s related to Realdash.
When my Android tablet is on its mount on the motorcycle, if I cut the power, I can’t turn off the screen. I keep getting “USB connected” and then “USB disconnected” notifications, and when I press the button to put it to sleep, the screen turns back on immediately.
The USB cable is plugged in, and there is an extremely low residual voltage of 0.4 mV.
Since there have been some modifications on the USB side, could this be a result of that?
Its very possible that is enough voltage to keep screen on. Maybe if you install Tasker on the tablet, you can tell it to shut the screen off at certain voltage.. i cant remember if that was an option, but i have my in tablet for my project truck running a task to shut the screen off and back on with loss of 12v and when 12v is sensed
Thanks for the suggestion.
I have Macrodroid installed on my tablet, but whether I turn it off manually or via a scheduled task, the tablet turns back on immediately.
I don’t think it’s because of Realdash…
