RealDash version 2.6.8
2.6.8 released 10.8.2026
Fixes:
  • Fixed multiline text issue.
  • Fixed coolant temperature issue on BeamNG Drive.
  • Fixed CAN speed selection not working.
  • Fixed crash on ‘Load Recent’ actions.
  • Android: Fixed file access issue on some Android devices.
  • Android: Fixed video sound keeps playing on non-looping videos.
  • Android 5 is no longer supported.
NOTES
A maintenance update, mainly to fix the Android file access issue on some devices that do not allow writing into public ‘Documents’ folder. On those devices, the old ‘private’ file model is used.
As Google forced an update to Play Billing library, Android 5 is no longer supported.
Android: Fixed file access issue on some Android devices - thanks / now all is good
Thanks for the timely update
im new, sim dashboard was kinda bad and not my taste, how do i connect to Rig of Rods? or is this literally a digital dashboard for actual track cars
Everything is working correctly. Thank you very much.
Does this Rig of Rods have telemetry output support? With quick look did not find anything from their forum.
How can I load my .xml from my tuner so i can read all connected pid’s? Its a EvoX running tephra V3.
Hello, I have a KIA Optima. Could you tell me which OBD2 parameter will show the fuel level in the tank, as well as the turn signals, headlights, and parking lights in RealDash?
Maybe this post will help to understand these parameters with OBD2:
OBD2 indicators, fuel level and gear - Connectivity / OBD2 - RealDash Forum
