RealDash version 2.7.3
2.7.3 released 14.10.2026
New:
  • Added support for webp image files
  • Trip view: Max Speed is now a button that jumps to location.
  • Trip view: Arrow keys left/right move one sample.
Fixes:
  • Trip view: now shows correct vehicle name.
  • Fixed errors on MRD file transfer.
  • Fixed networking issue with street info.
The Dash Data values are saved to the hard drive only if I press F2, not immediately after “setvalue”. I am using the Realdash 2.6.9 version from the manufacturer (Falcon S.)
Yes, it is not feasible to save every time after value is set. It is too easy to make a trigger that will set those values hundreds of times per frame, that would kill the filesystem pretty quickly.
2.7.3 may have an issue with all network connections on devices/computers without local TLS certificate. We are currently building a 2.7.3-2 update to fix this issue. Should be available soon.
I turn off the car, and after the dashboard wakes up, the old values load. Then make a special ACTION TYPE to save them — what are they even for then, if you need to remember to reload the skin every time after changing them?
They are saved at the app exit. I’m just building 2.7.3-2, I will take a look if save can be made more frequent.
Yes, thank you in advance! I never exit the app — it’s like a launcher. If I immediately reboot the dashboard, they don’t save.
2.7.3-2 is now submitted to Microsoft Store and Google Play Store. They should be available pretty soon. APKs are updated in My RealDash downloads section.
Hi. I tried to download an animated WebP and I couldn’t do it. The system returned an error. I’ll add a simple picture here.
1
This is a 31-frame animation at 1920×1079. Its compressed size is only 1.43 MiB, but loader tries to cache about 245 MiB of decoded frames and rejects it as too memory consumption heavy. We’ll investigate if we can loosen that limit.
Just a note, both apng and webp are extremely memory consumption heavy. While animated gif can be decoded “on the fly” to save on memory consumption, its not feasible to do frame decompressing on apng or webp during the runtime of the animation.
I understand you. I know that WEBP requires a lot of computing power. This is described in the format specification. However, it works in browsers so that it’s an easy thing to do. It turns out that the one who has to save memory uses it more than a weighty GIF. This is understandable, because the machine needs to process only 256 colors in the case of Gif. In the case of WebP, there are millions of colors. But how damn beautiful it looks compared to a Gif)))
Problema no gatilho Load Recent Dashboard
Was there any change to the ‘Load recent dashboard’ trigger?
*LEven with the correct name and the trigger working for other functions, the Load function doesn’t activate when triggered.
Hi! My name is Tiago, I’m from Brazil and I’m a RealDash user.
I really like the “New Boss on the Block” premium dashboard. I’m building a small personal digital cluster for my own car (Peugeot 207), running on an Android head unit with an ESP32 reading the CAN bus. It’s a hobby project, not for sale or distribution.
I would like to ask for permission to recreate the look of “New Boss on the Block” (the layout with the RPM bar along the side and top) in my personal app. I’m happy to buy the dashboard in RealDash first, and I would give full credit to the author.
Could you tell me who designed it and whether this would be allowed? If it isn’t, no problem at all, I completely understand.
Thank you for your time and for the great app!
Tiago
Design is really inspired by Ford Mustang dashboard, I do not see any issue re-creating it if you do it from scratch. You can also modify our premium dashboards for your own personal use.
