2.7.6 released 27.11.2026
New:
- Screamer: engine sound augmentation prototype and new Audio settings.
- Linux: Music Player → ‘Other’ shows track info, including from Bluetooth players.
Fixes:
- Fixed album art and track info sync over Data Multicast.
- Map rotation uses GPS speed; trip playback follows recorded direction.
- Trip Diary hides trips missing playback files.
- Improved UI rendering performance.
- Android: GPS starts after permission grant. Wi-Fi hardware is optional.
Screamer is our experimental engine sound generator. It uses live vehicle data to synthesize engine sound through your device’s audio output. Try an inline-six, cross-plane V8, V10 or V12, then adjust the volume and RPM multiplier. You can also choose naturally aspirated, turbocharged, or supercharged sound.
Normally, Screamer follows the RPM your vehicle reports. The optional Virtual Gearbox instead uses vehicle speed and throttle position to simulate RPM and gear changes. Virtual Gearbox option is mainly for electric vehicles without RPM info. Look for Screamer under Settings → Audio. Screamer is a prototype, we did it just for fun. If you find it interesting, we can continue tweaking it for the better.
Screamer requires fast data rate and proper sound system. RPM update rate of at least 10 times per second could be considered a minimum for proper sound simulation. Screamer is only available for My RealDash subscribers.
Audio settings are easier to find. The new Audio section brings together music player settings and controls for spoken navigation, notifications, and status messages. On Linux, the Other music player option can now show track information from compatible media players, including a phone connected over Bluetooth.
Maps and trip playback behave better. GPS-based maps now use GPS speed for heading rotation. When you drag the Trip Diary timeline backwards, the map still points in the direction you were driving at that point, not the direction you’re scrubbing.
We also fixed album artwork and track information falling out of sync over Data Multicast, improved UI rendering performance, and fixed an Android issue where GPS wouldn’t start after you granted location permission while RealDash was open.
