Realdash xml file on saab
Hi
I wanna make realdash from a android tablet with a canusb for my saab 9-3 og 2000. I found online can high and can low but where can i find the HEX file for my saab or if you know anyone that makes one? Am still waiting for my canusb from aliexpress and i will try to make it myself but if i fail doing it i wanna find a solution on someone that does those things. I never seen a saab have realdash on canusb yet
We do not have CAN descriptions for Saab either. If you ever find one, please share and we will put it into RealDash.
If the SAAB has a Trionic ECU, the data is in its description. The rest of the data can only be found using CAN Hacker.
The big problem is that these icons are not present in the bus.
is this what is needed http ://4 saab. com /T5Suite/Trionic5.pdf starting at page 99? also i have johnc compiadapter (can/bdm) for can reading is it possible to use that with realdash? compiadapter works with t5suite for reading and writing ecu but t5suite doesnt have customisable dashboards. had to add space because no links allowed
Seems like real time data CAN descriptions start at page 101. It does not seem to specify base address though, but did not take a closer look.
As for the CAN adapter, only these are RealDash compatible:
then probably this this?
github . com /mattiasclaesson /TuningSuites/blob/master /T5CANLib/T5CAN.cs
