Rename “triggers and actions” -
for a better understanding and coolness, as on modern alarms, I see the name for this section “FLEXIBLE LOGIC” or “SMART LOGIC”
What do you think?
Would definitely sound more smart
I noticed that the smart logic is attached to the .rd file
accordingly, if you program the logic to exit the application when the ignition is turned off, then when you change the skin, this logic will be unavailable, and it needs to be redone again, so the smoothing settings, for example, for the fuel level are tied to the sensor, and not to the input.
It would be nice to have a separate tab, which would have all active inputs in the form of a table or a list, which can be set to anti-aliasing and some other settings that need to be changed globally.
It would also be nice to have separate triggers and actions that do not depend on the theme, so that you can not reconfigure them when changing the skin …
There is Global Triggers and Actions option in ‘Settings->Application->2nd page’.
Thanks! stupid Russian!
