I think its best that you start by experimenting with RealDash OBD2 Monitor, which is in connection settings. There you can just type the OBD2 commands and see what is the reply from your vehicle.
ATSH command is used to set the header, and then you can request the PID. For example:
There are two CAnbus lines on the Reanult OBD2 port. I have access to two obdllink tools:
oblink mx+
oblink EX
I’m assuming that all standard applications will communicate with the “UCH gateway” for its PID via pins 12 and 13.
Or am I correct in thinking that it will use both canbus lines depending on how commands are sent down both lines?
I’d like to sniff the traffic now that I know the Dash CanBus is on Pins 6 and 14.
Can I sniff the traffic with these tools, and if so, what software should I use? Or do I need more specialised tools and/or a Linux operating system?
