Currently there is no easy solution for this. I will make an update that inputs ‘Time (local)’ and ‘Time (ISO-8601)’ will internally contain number of seconds since midnight. Then you can do the following trigger-action pair:
Create new trigger
Trigger condition: ‘Time (local) is greater than 64800’
Add ‘OR’ to trigger condition as ‘Time (local) is less than 18000’
Add some cooldown to trigger, like 10 sec or so to prevent it from triggering every frame.
On Trigger editor choose ‘Actions’ and add new action
Select action type ‘Set value on trigger status’
For ‘Select Input’, choose ‘Device Inputs: Night Mode’
Save everything.
The values 18000 and 64800 are seconds from midnight matching 5:00 and 18:00 o’clock.
So this would be on next release/beta, would this solve your issue?
I was able to do the above steps to activate the night mode. Thanks! But don’t know how to do the below… Nevertheless, night mode still gets triggered. May be you can advise on the below step. Thanks again
Dear Dev, as I said above, I did enable automatic night mode for all the three themes. (Benztown hammer, dash of color & new boss on the block). Except “dash of color”, the other two themes doesn’t change to automatic night mode. Both that don’t work, I have to edit and enable automatic night mode every time I change the theme. Even though I save after editing, the settings change to default and doesn’t retain my changes. Dash of color is the only exception. Can you please help or advise? Thanks
