I have an 2014 Honda Amaze automatic Indian varient petrol.
Gear indicator on default values in realdash app shows me running gear level however these levels are not correct because i am not able to calculate gear ratios and app defaults for sure is not match to my car
For some reason reverse and parking indicator are not working for me
As advised in various topics i tried to set new values but nothing happens
Setting>units and value>add then i select body electronics [select target input]>select input reverse light then it pushes me to a new screen to select source input and then shows body electronics one Of the options and when i select that it takes me to the page where all input parameters are there but not the new one i am trying to add.
Secondly, can anyone please help me to calculate gear ratios i cannot figure it out
Hi, as advised i tried to calibrate gear ratio but not of a much luck
Firstly it was hard to maintain 1200 rpm but i was in range of 1130 to 1270 for a good time but it was not calibrating and all of sudden calibrated gear 1 to 1.9xx
Then asked me to drive at 1200 in gear 2 to set gear 2 ratio. Since it is an automatic with no manual shifter so i cud not get to to calibrate gear 2.
Is there any pattern or technique to manipulate the same.
If your automatic transmission does not allow manual gear selection your only option is to enter the gear ratios manually into the popup you see on your screenshot.
That is my biggest issue. How do i calculate gear ratio. Is there a formula or any app which can calculate it for me. I managed to get gear ratio for the first gear using realdash calibration
I would really appreciate if someone can help me to get the gear ratio.
