Robotell canbus speed list N/A
Jani,
I cannot select the canbus speed setting for Robotell device. Realdash used to have a list to select.
BR
If speed comes from the CAN, it typically is set to VSS1. Select
‘ECU Speed Sensor’ for Settings->Units & Values->Speed Source.
Hi Jani,
Thanks. I am talking about canbus speed such as 95Kbps, 500 kbps…etc. i have to select the suitable speed to read the canbus data.
BR
Riiight. There was an issue that setting the CAN speed from RealDash did not work correctly with this adapter. Adapter stores the current settings in eeprom, so you basically only need to set it once. I used this Python tool to set the adapter CAN speed:
nopnop2002/Robotell-USB-CAN-Python: Python program for USB-CAN Adapter
