Hi just a request, add rolling drum like odometers?
make it with animation
Yes that would be awesome.
I mean, you can do it yourself. You can do the animation in REALDASH.)))
I’m not sure I understand?
You can make your burner move like a drum.
Need to edit _anim.XML file
It is indeed possible to do it yourself, but it requires that you create custom animations. We do have a 3D model of odometer drum roll in ‘Warmachine’ gizmo, I can check if its easily removable as stand alone gauge. This is not in high priority though so may take time.
Would be a pretty cool thing but yes you are right may take a bit of time.
I only came across 1 other droid that uses it.
https://play.google.com/store/apps/details?id=com.discipleskies.android.speedometer
